block weight
    block weight
    anyone know the weight of a bare stag engine block
    Not as heavy as a fully built engine -but heavy enough for a boat anchor according to the RV8 enthusiasts .
    Sorry can't help with precise weight, but I would estimate around 30Kg. No doubt someone on here with have one lying around and a set of bathroom scales to put it on.
      Dave your not suggesting Shaun (sax player) would use one on his RNLI Boat are you:shock:
      Stuart:P
        Stuart:P
          Weighed mine when I needed a rebore, around 12.5 stones IIRC
            I could carry mine single handed, but not too far.
              Are you talking about the block alone minus crank-shaft and pistons?
              The Rover unit is around 230kg including ancillaries. The Stag engine is 50kg heavier, so I guess around 270/280kg's for a full Stag engine.
              It was bluddy heavy when I removed it from my car; you'd need a big boat!
                The clue is in the original question
                "anyone know the weight of a bare stag engine block"
                  Estimate 30 kg?! Rather heavy pistons and crank would you say!
                    Time for some maths :shock:.
                    Density of Cast iron is 6800 to 7800 kg/m^3. (http://www.simetric.co.uk/si_metals.htm)
                    a 100mmx100mmx100mm cube would therefore weigh 6.8 kg - assuming the lighter 6800 kg/m^3 figure.
                    a 30kg lump would therefore work out to be 100mmx100mmx440mm. (Roughly 4"x4"x17" in old money) I would say that is considerably less metal than the Stag block!
                      Perhaps I was feeling strong last time I lifted one
                        Lol
                          apparently the correct answer is 75kg, i needed to know cos i bought a block and needed weight for courier
                          dougie
