I like the idea of fitting a header tank to reduce the loss of coolant and ensure the rad is always full. I know there have been articles but can't recall which tank is best fit. I found a Montego that looks ok as can swap pressure cap but similar to other headers it has 2 or more pipes coming from it, whereas I only want one,I guess it could be blanked.Any views/ideas please?
Header tank mod
seaside bill
I'm told the tank from a late TR7 willdo the jobif located up near the wiper motor. Presumably you'd need to splice the 'to radiator' hose into the radiator top hose and connect the 'to thermostat' hose to the radiator/expansion bottle hose?
For the ultimate in header tanks take a look at this:http://rides.webshots.com/photo/2843...46475909kouyuQ- sadly a one-off and not commercially available.
Goodness me, thats my header tank, i'm honoured, thanks very much!
seaside bill
mjheathcote wrote:I reckon there's money to be made if you got some ofthese made up - maybe SOC might help?Goodness me, thats my header tank, i'm honoured, thanks very much!
seaside bill wrote:mjheathcote wrote:I reckon there's money to be made if you got some ofthese made up - maybe SOC might help?Goodness me, thats my header tank, i'm honoured, thanks very much!
Put me down for 1 please
PS MJ what's the gauge for?It looks like it's in the fuel line .Very tidy engine bay BTW.
Cheesy
I am also interested in converting to a "header tank" set up.
Where can Ibuy the T piece required for connecting into the top radiator hose?
Thanks.
seaside bill
Cheesy
You can get anadaptor made up to your own specification from here: http://www.nfauto.co.uk/cut_tubes.htm
Also, if you download their PDF catalogue, you'll see ready made 32 & 38mm T adaptorswith a 15mm take-off on page 61.
Cheesy -
Stagdad wrote:Yes its a fuel pressure gauge. Okay a bit 'bling' these days but I fitted the Holley & fuel gauge over 12 years before 'bling'! It is handy though incase of any problems to check if you have fuel flow, but to be completely honest the Holley has caused me zero problems in all that time....soon to be replaced however with my own designed EFI inlet manifold with 8 throttle bodies.....:shock:PS MJ what's the gauge for?It looks like it's in the fuel line .Very tidy engine bay BTW.
Stagdad wrote:seaside bill wrote:mjheathcote wrote:I reckon there's money to be made if you got some ofthese made up - maybe SOC might help?Goodness me, thats my header tank, i'm honoured, thanks very much!
Is this a record braking "quote in a quote" attempt?
Cheesy wrote:I have a stub soldered into the rad top hose connection, justbelow the filling plug -I use theoriginal rad pipe as areturn from the bottom of the header tank. Tankmounted high, next to the wiper motor to keep the system full and self airbleeding.I am also interested in converting to a "header tank" set up.
Thanks.
Mark.
Thanks for replies. I looked at a TR7 header tank at a Stag supplier - while it would no doubt work it looked ermm well ugly,like something from a 1930's Morris,surely there must be better out there? The supplier put me off fitting, their opinion the system works well as it is, sucking fluid back into radiator on cooling.However my view is that if you have any coolant leak (and I've never found a dry V) then the level will slowly go down in the radiator and this will at least guarantee a top up.
I'll have a look around National day.
