Hi all, My stag sits slightly lower on the driver side than the passenger side (when looking at it front on), I see this quite a bit in older cars of different makes. Does anybody know what to do to correct it? Is it as simple as new springs?
Uneven Stag
Hi Martin
Mine does this also, some of this is due to the battery and fuel tank being on the same side plus the driver always being on that side weakens the spring over the years.
I am rebuilding my front suspension due to this and other reason and will let you know if it cures it next week.
Just as a not the passenger side spring I took off was about 1" shorter than the new one due to age I think!
Stuart
Stag77
MartinR wrote:Hi all, My stag sits slightly lower on the driver side than the passenger side (when looking at it front on), I see this quite a bit in older cars of different makes. Does anybody know what to do to correct it? Is it as simple as new springs?
Mine does too (sits lower on the drivers side), but then she is 32 years old! Just lookingat your alloys are they minilites they look crackin?
Mark/Stag77
MartinR wrote:Where is the cheapest place to get a full set of Springs and shocks?
http://www.jamespaddock.co.uk/Index.aspx?Category=1
Stuart
Guest
MartinR wrote:Hi all, My stag sits slightly lower on the driver side than the passenger side (when looking at it front on), I see this quite a bit in older cars of different makes. Does anybody know what to do to correct it? Is it as simple as new springs?Martin.
After the new shocks, I have noticed, because I looked, that the drivers side is down compared with the passenger side :shock:. I should have been suspicious when it was easier to get the bearing back-on compared with the nearside.
Why did I let Stuart talk me out of buying new springs!:?:?:?:?
