Hi All
During the last few months I have notice certain parts of my car that need attention which I am slowly trying to rectify.
Firstly there's the front suspension and brake project which highlighted an area of corrosion cost so far without fitting the new splash panel £320.
I have been quoted by E J Ward £250 to fit the splash panel and have also asked my local paint guy to quote who thinks it will be more as paint will be necessary
I was going to fit the panel myself but stopped when my paint guy said paint was needed
I then have the rear wheel arch to move onto afterwards and have been told by E J Ward that the best (only) way to repair this 3-6" of inner arch to outer arch (this outer is solid)corrosion is to fit a new inner arch and 3/4 outer wing repair:shock:to do both sides ( I asked for both to be quoted as I believe if one side is bad the other will not be far behind!) it will cost £1800 -£2000 to repair.
Why is nothing ever easy on a Stag? Why do you have to rip off what look like solid outer panels to repair the inners?
Is it the case that this is the only way or are the specialists out to rip me off?:?
At this rate I have got to budget at least another £3500 to get the car top notch with new Soft top and seat re trim so it will last another 20 years.
I am seriously considering is this really worth the expense!:?
NOTE: Repairs to bodywork only necessary due to poor workmanship carried out during the previous owners time!:X
I know I am really critical of my car but is it only me who is paranoid about what is going on under the paint and under seal?
Stuart
.I was going to fit the panel myself but stopped when my paint guy said paint was needed
. I then have the rear wheel arch to move onto afterwards and have been told by E J Ward that the best (only) way to repair this 3-6" of inner arch to outer arch (this outer is solid)corrosion is to fit a new inner arch and 3/4 outer wing repair:shock:to do both sides ( I asked for both to be quoted as I believe if one side is bad the other will not be far behind!) it will cost £1800 -£2000 to repair.
Stuart
- which was the reason I let my heart rule my head and bought mine.
), as the cost of restoration and repair will never be recouped. I must admit personally half the fun of a classic car is the constant battle to keep it on the road.
