PCV based crankcase ventilation
    There have been other people doing their own similar systems before but in response to a couple of requests for photos of my particular PCV setup, I have written up the details in a seperate pdf file here for interest.
    Thanks!
    I've been thinking along the same lines, but maybe not such large connections into the existing cam covers.
      I went for large connections to allow for room for the PCV valve and grommet and for a lot of room so that the flow rate of the vapours is reduced allowing any oil mist to condense and flow back down. I had quite bad oil blowing into the air filter with the original side pipe and straight connection to air filter, that I tried to make as many stages of oil trapping as possible. It may not all be necessary but the basic principle of PCV and a vent on each cover seems to be a common setup on a few 'V' engines I've seen, so I guess that is a good indication.
      Regards - Jon
        Thanks for the photos Jon its a lot clearer now. Regards Peter
          hi posted on this before here are some pics of my setup
          works well
          alan
            works well
            alan
              alan230752 wrote:
              works well
              alan
                Nice! I can see you have spent a lot of time and money on that engine. How much does chrome plating cost nowadays out of idle interest?
                  hi
                  all my chrome work ,under ungine and all exterior parts were done my ray hodge
                  who sells on ebay under the handle flyingfinch
                  he is based in essex
                  and does an excellent job at reasonable rates
                  alan
                    Hello Alan.
                    I am dazzled by the shine! Please will you clarify the plumbing. I assume that is a catch tank on the N/S suspension tower. Input from PCV on N/S bank and output into PCV port on Holley? What have you done with existing breather on O/S bank?
                    John.
                      yes n/s cam cover contains pcv valve which runs to oil catch tank
                      from there it runs to pcv connection on holley
                      the original o/s cam cover vent then runs to undernath air cleaner base
                      which incedantly at service intervals has no oil mist or spray inside,which shows that system works all ok
                      alan
