I was talking today to the manager of a reputable motor factor outlet about antifreeze. I asked what he knew about the different types (traditional Ethylene Glycol vs the newer OAT types), their suitability for different types of car and their compatibility if mixed.
He stated that if you mix the two types you will get a gel sludge that blocks the coolant passages, and will need to replace the radiator and power flush out the engine.
Is this scaremongering or fact based?
I think the risk is low, but it's worth taking the precaution of never mxixing the two types just in case. Here are a couple of paragraphs from an AA website you may find interesting ( my highlights not theirs): http://www.aa-academy.com/asp/info.asp?id=72
"Silicate levels in G11 antifreezes vary. The level used to be as high as 1000 ppm, but this has been reduced to around 250 ppm.At this level there shouldn’t be any precipitation of silicates if mixed with another type of antifreeze.You may have heard of, or seen, cases of horrible green/yellow gel/sludge in the radiator if different types of antifreeze are mixed. BMW still favour a conventional high silicone green anti-freeze.
A combustion gas leak (resulting from head gasket failure) will deplete the corrosion inhibitors as the carbon dioxide dissolves in the coolant and forms carbonic acid.
Now the risk of silicate precipitation has been reduced there is still an issue with different corrosion inhibitor packages which can work against each other."
