marshman wrote:
Hi Roger,
Thanks for your reply. That gives me some things to check.
The bulkhead terminal you mention, is that on a mk2 as well?
I don't remember putting anything back or connecting any wires to it!
I cannot get my alternator plug in and out without loosening off the alternator, is that normal?
Rgds....Al
marshman wrote:
Al,
Sounds like a direct short circuit. Most things have a fuse protecting them so any significant current, and I think melting battery leads are in that catagory!, would blow the fuse.
Do you remember the thread about two weeks ago about what goes where under the bonnet. There was the positive terminal on the bulkhead just behind the RH exhaust manifold. Vmad (I think) said to make sure it was covered as it was easy to short things out on it. Did you completely remove that terminal for spraying, if so did you refit it correctly?
Check that the positive feed to the starter solonoid is not earthing out at either end.
 Pull the plug from the alternator as this has a direct feed from the battery then see if the short is still there.
One way to check without risking damage is to connect the positive battery lead via a light bulb. If there is a short to earth the bulb will light but no big sparks and melted leads.
Don't use a ammeter because if it is really shorting out there could be a few hundred amps flowing.:shock:Â and it won't like that much.
One last thought, what about the square block on the bottom of the inner wing - the one not fitted to a MK1? is that fitted correctly?
Good Luck
Roger
Don't use a ammeter because if it is really shorting out there could be a few hundred amps flowing.:shock:Â and it won't like that much.One last thought, what about the square block on the bottom of the inner wing - the one not fitted to a MK1? is that fitted correctly?
Good Luck
Roger
Rgds....Al
