Show me your bumps!
    Show me your bumps!
    Ok maybe not as interesting as you may have first thought!
    But I am making good progress (at last!) on the supercharger front ( After a pep talk from Grahamb's son michael!) and this is the state of play.....
    Crank Pulley and waterpump pulleybeing machined up (They need to be 8 rib poly belt profile machined to fit fit rover, Supercharger mount "mocked up" and awaiting pulleys so everything can be lined up before the mounts are machined up in 10mm alli plate.
    Parts have arrived from the "states" to complete and one of the parts has caused a bit of long face...............The carb bonnet, it's basically a funnel to connect the charger to the carb. Well it's a bit high at the moment....about 2" too high......So my bonnet wont close!!!!!! So it looks like I might have to go for a bulge! (obligatory "Ooh Matron!")
    So just for the ROVER V8 owners would you mind showing me your bumps so I can get an idea of what it would like?
    Cheersssssssssssssssssssssssssss
    This was before i remodelled the body work and sprayed it white.
      :shock::shock::shock::shock::shock::shock::shock:: shock::shock:
      I can see why you might need a Beemmer rear end!!! :P
      SSSSSSssssssss
        Surely there must be some RV8 owners on here ? ...................anybody...................
        Sssssssss
          I can't find a pic of it, but the 4WD Stags had a subtle bulge in the bonnet.
            Here's one
              Thank you for your input dave I will do some reaearch on your suggestion......I did think I would unnerve the "purists" about talk of "modification"..
              But at the end of the day we're all the same..........but different...........
              Ssssssssssssss
                Kevin Garrod wrote:
                Here's one
                Ah... quite subtle....unfortunately too small not that I'm being sizeist or anything! (is that the way you spell Sizeist?)
                Seriously this carb bonnet is really a mother!
                SSSSSssssssss
                SSssssss
                  This one then?
                    Kevin!.......................for the love of decency why did you have to show THAT!!!!!!!!!!!!!!!
                    That is so subtle....................NOT!!!!
                    SSSSSSsssssssssssss
                      how about russ spakes avatar pic.
                        Isn't this car in this months Triumph Mag? Not sure as i was cheapskating and looking at it in Smiths
                        Phil
                          Apparently they had to lift the engine a bit to fit the 4wd system underneath, hence the bulge. I bet a tuned one of those would shift a bit.
                            Thanks for the input chaps I think the bonnet bulge on the 4x4 stag is great inspiration....
                            Sssssss
