All,
After having my suspension replaced all round (new springs and dampers) I ended up with what could be classed as an 'off-road' looking Stag.
At the time, the suppliers and fitters of the parts said to allow a few hundred miles for everything to settle. I allowed 3 years and still it sat 'high'.
After searching through this forum and talking to a few Stag owners, I opted for:-
HRS lowering kit
Standard front dampers
Spax adjustable rear dampers
I asked a local Stag specialist to fit it for me, which they did, however when it came to fitting the rear trailing arm brackets, supplied with the kit from HRS, they refused saying it would give the car positive camber, look ridiculous and handle badly.
With the originals still on the car, the rear wheels had a lot of negative camber and looked ridiculous anyway, but they argued that the car would handle better with more negative camber than with positive camber.
I've drove the car for a year, during which I spoke to HRS about what I'd been told. He informed me the brackets would correct the rear camber by 2-3 degrees.
As a result I booked the car into a local garage and had them fitted.
Before I did so, I measured the camber angles...
Rear driver = -6 degrees
Rear passenger =-5 degrees
After the brackets were fitted I measured the camber angles again...
Rear driver = -0.5 degrees
Rear passenger = +0.5 degrees
The manual shows that the rear camber should be:-
-2.5 degrees (+/- 0.75 degrees)
So, on first experiences it would seem both the specialist and HRS are wrong. They are pretty much vertical.
The question is this... what would you do now? How critical is the rear camber? Is it dangerous in its current set up?
I could buy adjustable brackets from Monarch, but they are expensive.
All suggestions welcome...
HRS lowering kit
