Hi All, I think I have a problem and require your expertise.....
I have flushed out the cooling system(twice now) last time did not drain the block on the near side. New coolant put in 35 % mixed with ionised water.new 20/50 oil from halfords( all done yesterday)
Volvo header tank fitted to modified rad 2 months ago( thermoswitch, drain plug, outlet fitted near neck for top of Volvo header tank, lower outlet fitted for bottom of header tank), kenlowe wired to thermo switch ( which is locatednear top of n/s on rad) switch opens at 90 Degrees.
I have checked whether head gasket is blown by taking out spark plugs and cranking engine, no water spitting out, no air bubbles in header tank, oil ok not milky at filler plug.
My problem now is yesterdaythe temp needle was over the3/4 mark on the dial, today I fitted in new thermal switch,new stat,new gasket, Kenlowe kicks in as it should. but i did notice when changing thermal transmitter that the old red coolant came out of the head:?,.....waited until the new blue coolant flowed out then put in the new thermal switch now tempjust over half way, only because kenlowe kicks in. this evening after the test run the temp was over thehalf way mark, when i parked up after switching off the engine I left the ignition on and the temp slowly raised up to near the red....
What else can I do to?,......Your views will bemuch appreciated.
