intreior lights
    intreior lights
    i have no interior lights,puddle lampsworking plus no electric windows bought car about 6 wks ago previosly stood under cover for 3 yrs. i no this is probably the least of my worries but it is a pain. any suggestions would be welcome.
    Hi Paul and welcome, Have you checked all the fuses? If yes, find all the elecrical connections to the doors, pull them apart and clean with WD40. Also pull out the light switch in the centre console and clean with WD40.
      You could try pulling off the purple wire off of the back of the fuse 1-2 Battery control and powering it up direct from the battery +veor just use a test bulb to see if that fuse has power to it.
      Cheers Steve
        hi jason, tried the wd 40 on centre consol i now have interior lights,now just need puddle lights on doors to work. result. regards paul.
          hi steve, thanks for advice i new that loose purple wire had to fit somewhere.regards paul
