Fibre washers at petrol pump
    The poxy fibre washers have failed again on my petrol pump, I just put new ones in today and there is still a slight leak !
    Has anyone found a proper fix for this never ending problem ?
    Is there a sealant that works with Petrol ?
    Stu
    Hi Stu
    I put copper washers on mine and have had no problem since . Your local spares shop should be able to supply them
    Tony
      Stu
      Hiya Stu, the fibre washers for the SU pump are apeculiar size, they are black and appear to be a different material to the usual red ones, if you Google / contact Burlen, they'll supply them. One thing worth trying if you have the right washers is PTFE tape, it's completely petrol proof. One quick thought, I had one banjo union that had an air hole in the casting, that bugger took some finding, very unlikely but if all else fails . . . Martin.
        When I changed my pump I fitted new banjos and washers(normal red) from SOC spares. She dripped occasionally for 6 weeks---but has been bone dry for many months now
        Darren
          Thanks for the feedback, I will see if the drip stops in the short term, if not I will wrap the washer in PTFE, failing that its try the copper
          Stu
