brake problem again
    brake problem again
    went to give it a run today and no brakes went to check fluid empty looked at calipers and rear cyls dry? drivers footwell vry soggy lifted out matt soaked with fluidi assume this is the m/cyl leaking into the servo and passing through any one else had this,second servo and mcyl in 13 months.warranty out:X
    so what do you do throw more money at it with recon or new stag bits or go down the bmw servo/cyl route at about the same cost?
    anyone rebiult the servo and m/cylinder thats the cheapest option at about £70 as opposed to replacement at about £235
    oh and just for good measure my engine has kindly painted the entire underside of the car with oil from a leak i cant find.
    the best is i just needed a quick fix before i changed the exhaust system to a new st/steel one the old st/st was rotten yes holes had appeared in various places.
    begining to wonder if maybe we should part company.one very p........d off stag owner....................rant over.................... steve
    I would go for the BMW m/c and servo since yours needs replacing
    Just in case you would like to have a go at doing the conversion yourself the bmw m/c and servo that monarchs supply is from a E30 3 series, and you can get a new m/c from GSF car parts for £70
    I plan to have a go at doing it myself as i have a spare peddle box to play around with, i could just to with the fitting instructions from a monarch kit
    Stu E
      Steve ,
      Sorry to hear your wows,I tried a M/c repair kit when i got mine but it didn't work ,bore must have been shot,i'd go for the BMW one but if you have a manual o/d you will need to get someone to weld the clutchbracket for you as for the oil leak,there's a lot of it about .
      Cheers Steve
        Stagdad wrote:
        Steve ,
        Cheers Steve
        thanks for the tip steve about the weldingand nice of you to offer:Pbet your just waiting for something to break so you can get you darth vader kit on.probably will go for the beamer kit like stu e says they can be bought from gsf cheaper just need to sus fitting out . didnt realise you had to move clutch cyl as well though.think i might of upset the neighbours fired it up with only the tubular headers on god it sounded AWESOME........................ steve.
          Steve you hooligan
            Stagdad wrote:
            Steve you hooligan
            Did that years ago to my mates Lancia Beta, flames shot out to the ground (car up on ramps) and the neighbours kids who were watching, s**t themselves and did a scooby doo start trying to run away......those were the days
              Stagdad wrote:
              Steve you hooligan
              Please put it on U tube!!!
              John.
                Tha sad fact of this, Kevin, is a few years ago the kids would have come back and said 'do it again please, mister!'
                Nowadays you are likely to get Plod on your doorstep saying they had received a complaint from the parents that you had frightened their 'little darlings'!
                That's Life!
                  You're probably right Dave, but it wasn't my house or my neighbours!
                    KOY 23 wrote:
                    Stagdad wrote:
                    Steve you hooligan
                    John.
                    john im away till monday , but might see if i can get my lad to film it and put it on before i get her reffitted this week.watch this space...........ps i might get an angry mob:shock: but the other half of my close should defend me unless they plan on getting there boilers and electrics sorted by others and paying thru the nosesteve...........
                      Just let your son do it and claim ignorance!
                      John.
                        well got back from scrabster this morning and decided to go with new stag m/cylinder from ld parts.WHAT A REALY HELPFULL BLOKE PETER IS after a long chat with him sussed out as he said that it is not servo leaking as well but fluid being blown and sucked into the foot well behind it......... so ordered new cyl with st/steel sleeve.
                        do want to go to bmw mod but will wait and collect parts first and make brackets /welding etc.informed opinion seems that it is a better system but need to get car back on road quick no fun just staring at it when the suns out
                        steve.......................
                          Yep ,you've got to make the most of this weather Steve,met Peter a couple of times and he is as you say areally helpfull bloke,
                          Cheers Steve
