Steering Wheel Shake
    Hi 3rd Post Have Got Steering wheel shake at 50 mph, Seems to be just at this speed ok before /after is it Wheels req balancing / top bush on S/coloumn or something more sinister . Thanks Doug2008
    I would say get your wheels balanced first and then see what it is like. Normally if it happens at around 50/60 mph and you are able to drive through it then it is wheel balancing.
    Nigel
    Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
      Thanks for warp speed reply will do that first regards Doug
        I concur, it's usually wheel / tyre balance at 50 - 60 mph.
        Regards, John.
          Hi Doug
          I agree it will be wheel balance but before you take it to be check jack it up and check for play in the wheel bearings
          Stuart
            Nigel
            Why only at this speed???
            no matter what year or what car or rim size.... it seems to be only around this speed WHY???:?
              Hi guys had wheels balanced, problem solved, thanks again for your help regards Doug2008
                Hi Doug
                Glad to hear the diagnosis was correct.
                Nigel
                  Top tip: Wobble through the steering wheel - front wheel(s) need balancing. Wobble feeling through the seat - rear wheel(s) need balancing.
                  Red alert though -If you have a very strong rhythmic wobble through the steering wheel at very low speed then STOP and get out to check the front tyres.
                  I wrote a front tyre off by running it while totally flat. Oops.
                    Another top tip - a little bit of wheel imbalance not normally felt will be amplified many times by any play in the lower balljoint to a real "wheel shaker" - judging by the quality of many of the "new" parts being supplied nowadays, the lower balljoints don't have a very long life.....
                    Russ:dude:
