IGNITION LEADS
    IGNITION LEADS
    Hi guys!
    My mk2 fitted -orriginal v8 has had a LUMINITION fitted....
    no probs- but am curious about fitting " performance silicone type" ( RIMMERS GCL132MS) instead of orriginal green type fitted...has anybody out there in Stag land fitted? and is their any obvious improvements??
    :dude:CHEERS!
    PHIL
    No!
    Standard stag thrashed and enjoyed, Nissan Murano ( very underrated, very thirsty, very fast)
      The original green OEM leads are rubbish, even new ones can fail quickly. Saying that, if you have a set they are working, they are working and I don't think you can tell the difference over silicon ones...but for how long?
      I had a set of Hella 7mm silicon leads for nearly 20 years before swopping for a custom set of 8mm Magnecor silicon leads.
      I only changed them for they had become scruffy, still serviceable.
      Like most things, you get what you pay for!
        I bought a reel of copper cored lead 10m I think and some end pieces from the interweb, and I made them up myself as I was unhappy with the length of some of the standard leads ( very untidy you know) plus the cable I bought was a nice yellow colour. Worked for 20 years no problem!
          Just fitted a set of the Rimmers leads, big improvement over my 9 year old green leads. Bit fiddly getting the lengths right, more of a problem on my Stag due to the coil being moved in the past. As someone else said you get what you pay for and I wouldnt bother with the original green type leads.
            I agree, don't bother with cheap leads. I also fitted new ditributor cap and rotor at the same time. Made a big improvement.
              If you have not already come across it, do take a look at the LDPart website at http://www.ldpart.co.uk - specialises in Stag spares and currently offering a very reasonably priced (£19.27) complete ignition lead set. Each lead comes with little number label so even a complete dipstick like myself can get it right! Distributor cap also available for under a tenner. Lots of useful advice, tips and links as well.
              Usual disclaimer of having no connection other than as a satisfied customer - order turnround time is awesome. LDPart's proprietor, Peter Howells, ocasionally posts to this forum and is an active SOC member.
                :dude:Hi Wildstag!
                Thanks for tip! and all guys for the info!!! ....conclusion gonna ditch the green uns on balance of all opinions!!!
                CHEERS TO ALL!
                :dude:PHIL
                  Phil,
                  If you intend to use the original cam cover clips, you'll have to watch for going too big on the diameter of the leads. There's a chance you could damage thicker leads by cramming them into the clips.
                  Just a thought!
                    :dude:Thanks for tip Cheesy! all most welcome!!!!! ......I keep lookin out for your STAG!? sure our paths will cross one day!!!
                    :dude:All the best!
                    PHIL
                      Valid point but I find my 8mm leads clip in fine with very little force
                      Cheesy wrote:
                      Phil,
                      Just a thought!
