I've managed to find the time to measure my valves clearances, which in general are not far out (couple of thou) from when I last set them on the bench 10,000 miles ago. As I want to tighten them up slightly I have removed the camshafts and measured the shims that I fitted.
Surprisingly in 10,000 miles from new, all the cam buckets have to a larger or lesser extent worn in the middle body and very bottom. This was the case when I last rebuilt the heads too, but at that stage I did not know the mileage they had done. Also the right hand head buckets (UK off side) have more wear than the left hand head ones, the right hand head always runs hotter than the left by 5 to 10 degrees C...
Anyway, the worst case bucket has a major diameter of 1.312 inches (assume same as a new unworn one) and a minor diameter of 1.307 inches at the max wear points. Therefore 2.5 thou wear.
Is this acceptable and normal is the question?
All cam bearing surfaces/cam lobes etc are all lovely and clean, no scores etc.
Thanks,
Thanks,
