I'm querying the assembly of sleeve, bearings and washers in the top mount.
I'm reusing the above mentioned components in new mounting rubbers 138876. The rubber in the original mounts, both sides,had become detached from the internal liners and had to be replaced, all the other components were seized in place which probably explained why the rubber had sheared from the liner.All the component parts however cleaned up well and I'm quite confident in their reuse, however I'm puzzled by bearing 138598. It was a swine to press out of the old liner, even though it is a split or spring bearing; it should have been easy to remove. The thought is that it was fixed in place by loctite or something similar. Was this correct? Or should it be free to float between the liner and the sleeve 138599?
