exhaust tip
    exhaust tip
    managed to get my new exhaust system fitted have been using a high temperature red flue mastik(silicon based) for donkeys years at work on gas and oil fired burners at extremely high tempsit never fails and is easy to strip again works on stags tomuch better than the concrete stuff you get at motorist shops and neater.available from most good heating suppliers or plumbers merchants.
    steve............................................. ......
    I have an exhaust tip as well.
    If you replace all of the subframe hanger bits, buy bolts that are 1/4" longer than the parts book reccomends. It is just about impossible to get the nuts on with the standard length bolts.
      I have an exhaust tip too......
      It's the bit at the very end where the gas comes out........
      Although I more often call it a tailpipe:P
      Russ:dude:
        I've got two on mine :P
          LARGE bore or small bore :P
          Adrian
            Adrian
            Now lets not get personal :P:P:P
              StagnJag wrote:
              Adrian
                Adrian
                4 bore
                  Its quality not quantity that counts :P:dude:
                    Stagdad wrote:
                    Adrian
                    4 bore
                    Show off :P:P
                      STAG1973 wrote:
                      Stagdad wrote:
                      Adrian
                      4 bore
                      Show off :P:P
                      Well ,i thought i've got 4 barrels going in may as well have 4 coming out:P
                        Stagdad wrote:
                        STAG1973 wrote:
                        Stagdad wrote:
                        Adrian
                        4 bore
                        Show off :P:P
                        Most of us have 8 going in. You swapped to a Dolly/TR7 engine have you?
                          DJT wrote:
                          Stagdad wrote:
                          STAG1973 wrote:
                          Stagdad wrote:
                          Adrian
                          4 bore
                          Show off :P:P
                          :PDave i think you know i ment the 4 barrel carb.
