Hi All
My car is a 1976 Stag Mk2 and according to the serial number which ends with an A it should have a BW65 box fitted, however the previous owner has replaced it with a BW35 for some reason:?.
Today I took the prop to have new UJ's fitted and found out that the front yoke is badly worn and the 'bearing cup' is spinning in the bore:shock:. During this inspection at Proptech they noticed the front spline nose appears to be sticking out of the box 10mm further than they would normally allow.
Question is there a difference in length between the BW65 box of prop compared to the BW35 box or prop?
They told be I need a new propshaft and can make me one for approx £120 with heavy duty UJ's fitted.
Stuart
Stuart
