Rad fan switch setting
    I'm looking to fit a rad switch for my 2spd Kenlowe fan. I've had a boss put in the rad along with tubes for a header tank.
    The currentKenlowe rad capillary turns the fan on when the capillary temp gauge reads 95, about right I reckon. I was about to buy a new 93/98 switch but wonderd if the rad is actually a lotlower than back of head temp.
    I bought a couple of scrappie switches with 3 wires,one turned on around 70/80, too low I reckon,the other onlyhad one setting 90.A while later I pulled the connector off to find it only had 2 prongs inside:shock:
    So whats do you reckon would be the ideal rad temperature to aim for, what temp are the top hose fan switches set to?
    BTW - I did look at the top hose switch but apart from the price, I wanted to automate the 2 spd and wary of leaks - like the Kenlowe does.
    paul
    I have a pacet fitted and after playing around with it for a bit i have set it a 90 seems ok at the moment.
    Adrian
      Thats 90 in the rad?
        Sorry should have read the thread properlythat is what my theromstatic switch is set at.
        I see what you mean about setting at 70 - 80 the fan is constantly on..
        Adrian
