:dude:hi guys , can anyone tell me how i can test the wiper motor, useing a live feed from the battery to see if it works, paul
wiperless
Hi Paul
Try this. Disconnect the wiring block that is wired into the wiper motor assembly.
Inside are 5 terminals 4 on one plane and 1 at right angles to them. Try to imagine the single one as the top an inverted U. Putone wireon that terminal. By putting your other wire on the either of the 2 terminals on the left you should be able to make the motor operate at 2 speeds. Hope that makes sense. Careful you don't short anything out...use spade connectors if you can
David
