Hi all
I have just bought a 1977 Java Green example, and although it's actually a reasonably up-together car there are a couple of niggles that I would like to sort out before I go too much further because one of them is quite confusing.... especially at night.
The headlight stalk is on dip beam when pushed forward and main when pulled back - the main beam flash is still there on the spring detent as normal....... this as far as I know isn't right, and very unlike all the Dolomites I had years ago. The car has been resprayed at some point in the recent past, but is it possible for the wiring to be got wrong at the lamp end and still leave the main beam flash working as normal on the stalk - I await your comments....
Secondly, the wipers. The off position is slow speed, the '1' position is off with no park, and the '2' position is fast wipers. Could this be the limit switch on the motor or do I have to start looking for incorrect wiring, along, possibly with the headlamps?
Third and I won't bore you anymore, the engine can run quite warm when in traffic and when steamed up the motorway - up to 3/4 on the gauge - having the heater on helps, so suggesting a radiator issue. It appears to have a very new radiator but have no way of knowing if it's just a standard rad that I need to uprate or an uprated rad and I have other problems such as water pump or similar. I have an extra electric fan in addition to the standard viscous fan which seems to be OK, there is no coolant loss and itis fully antifreezed.
How do you tell what radiator you've got? And who makes the best uprated rad?
 Could be worse, the figures could be the other way round..... the basics are all done and it's mainly tweaking with things like getting the soft-top seals right, and the detail stuff that takes that bit more time.
