Evening all,
Since re-building the underside of the vehicle over the last few months, I have experienced a few issues with an apparent lack of fuel getting to the engine once it has got hot.
The first time I noticed this was after I had had the engine idling for about 30mins, and the engine spluttered and cut out. I dismissed it at that point seeing as the vehicle had been laid up for a while. Once it was cold again it started and idled fine.
After getting an MOT on the vehicle I have driven it twice, and on both occasions it has spluttered to a stop after about 20mins.
The syptoms I have noticed are:-
1. Engine pops & bangs before stopping (running lean asfuel runs out)
2. Fuel pump does not tick when engine dies
3. Fuel filter gradually empties before engine dies.
4. Pump ticks, filter fills completely and plenty of fuel flow when cold
5. Only happens when engine is hot.
Having searched the forum, there are various topics that seem to cover this type of issue. Some can be found here http://stagownersclub.mywowbb.com/se...uel+starvation
Following suggestions from these topics I have done the following, but to no avail:-
1. Cleaned the contacts in the original fuel pump
2. checked power to pump - 12v to pump and good earth whilst symptoms exist.
3. Dismantled and cleaned inertia switch (wasn't bad to start with)
4. Cracked off fuel pump outlet and fuel spurts everywhere and pump starts ticking
5. Fitted new electronic fuel pump
6. Changed ALL rubber connecting hoses along fuel line in case they were perished
7. Blown air through all fuel lines
8. Fitted new fuel filter
9. Checked fuel pressure regulator & OK
10. Checked the fuel pick-up and it's totally clean, as is the inside of the tank.
I'm now a little puzzled, as the fuel system seems totally clear, in fact the engine runs fine when cold, and pulls V well up to 80mph, until it gets fully hot and you slow down. Suggesting that the issue only occurs when the the engine is hot, and there is less air flow through and under the vehicle.
In one of the posts it suggests that with new silencers (without a heat shield), the fuel pipe can be heated up to the point where the fuel vapourises. I can understand that the fuel can vapourise, but surely the pump would just push fresh fuel through the pipes to the carb. But the pump just stops pumping, as if there is a blockage!
Is it likely to be vapour lock, and would shielding the fuel pipe help? And can a vapour lock stop the pump from pumping?
I would appreciate any thoughts on what to check next, as I am fast running out of ideas!! Or has anyone else had this experience, and/or solved this kind of issue?
Many thanks
James
P.S. Engine is 3.5 RV8 with Holley (recently rebuilt)
Many thanks
James
