Front sidelights
    Front sidelights
    I know the subject of LED's has been mentioned numerous times, but are there any that replace the front side lights bulbs that are the same fit as the 5 or 6w bulbs?
    If so, where can I buy them from?
    Andrew
    Hi Andrew
    Are these what you are looking for :-Ebay 300331676777
    Also search for T10 LED there are loads on there.
      Hi Steve, excellent and I wonder what they are like compared when fitted. May get a couple and thanks for link
      Andrew
        They got to be better than the candles in a jar we have now. There are cheaper ones on there.
          Actually Steve looking at the design of them, they just push in like the front side indicator bulbs rather than the ones that fit with a twist
          Have I got it wrong
          Andrew
            Sorry,my fault,I was looking at the bulb for the wing indicators. Back to the drawing board.
              The bulb equivalent is theGLB989
                Hi Andrew
                Try these instead - 120422954940
                The bayonet is 9mm, what size are our bulbs?
                  ive got the led lights in my bike, just cant remember where i got them, i think it might have been halfords
                    Does anyone know if these can replace the front sidelight bulbs being the GLB989's?
                    http://cgi.ebay.co.uk/4-LED-Xenon-HI...d=p3286.c0.m14
                    Does anyone have access to a cross reference chart, if there is such a one?
                    Andrew
                      Found the answer, they are BA9S's
                      http://www.geomatique-liege.be/MGJP/Pages/Ampoules.htm
                      May get a couple to see if there is an improvement
                      Andrew
                        A few choices here. The Stag is listed under Rover (Triumph)
                        http://www.autobulbsdirect.co.uk/233-LED-bulbs/
                        Pete
                          Hi Andrew, it's probably worth mentioning that they won't be any brighter than the originals, but of course they will last 100 times as long. Martin.
                            Bugger, I have just ordered them but as you say they will last longer
                            Cheers Martin
                            Andrew
                              Martin, you were absolutely right. It was a shame that I had already ordered them before your advice.
                              They arrived, fitted well and seemed very bright indeed, then when I put the lens back on I realised how blue they look compared to the warm glow of a normalbulb. When I putthe headlights on, the sidelights looked awful. Now back to using normal bulbs and will use the LED' so my daughters dolls house or something.
                              Take heed anyone thinking ofgoing LED's
                              Andrew
