Distributor refitting
    Hi All
    Just want to check I have done this right?
    When refitting the dizzy I brought the No2 piston to TDC the refitted the dizzy, the rotor arm was facing the screw on the outer body next to the vacuum advance/retard unit is the right?
    Stuart
    Hi Stuart,
    The rotor should be pointing towards the outboard ignition coil mounting bolt:
      Hi
      I thought members might find the attached Stanpart diagram useful
      It shows the plug lead connections and numbering for the distributor cap
      Marv
        Stuart, As dave has already said you need to point the rotor arm to the offside coil mounting screw which means pointing it to the middle of the coil when you insert it and the helical gear moves it back to the correct position when you push it down.
        It goes without saying make sure you are on the compression stroke of number 2ie the timing marks align with the 0 degrees mark. - Alan
          Marvstag wrote:
          Hi
          Marv
          All you have to do then is swap leads 3 & 5 around.
          Firing order is 1-2-7-8-4-5-6-3
          Good old BL.
            thanks for spotting this - I will amend the diagram and re-post it
            marv
              This is the amended diagram with the correct firing order!!
              I will have to go back and correct my Stanpart catalogue
              Hope this helps all who are stuggling with which lead goes where!!
              Marv
