I am putting a refurbished Starter Motor on the Stag.
The Manual states "Remove top mounting bolt, nut and washer. This operation may be achieved working from above the engine using socket on forward bolt head with extension build up running forward so ratchet spanner may be used adjacent to cooling fan.Rear nut may be held with open-jawed spanner"
Neither of the bolts holding my starter motor in place have a rear nut ? They simply bolt into the engine plate, is that wrong or am i mis-reading the manual.
I also take it i need a very long extension for my ratchet spanner - some 500mm to undo that bolt.
Dazza
Dazza
