Water Drian Holes Help !!!!
    I was washing the Stag this evening for the first time since I purchased this car and noticed something strange when i opened the doors to chamios the door shuts etc.
    I opened the drivers door and water poured out of the gap around the lower door hinge however when opening the other door no water came out?
    The car has had new door skins fitted by the previous owner (professionally)but after looking at the bottom of the doors there appears to be no drian holes!!! :shock::?
    Should there be built in door drian holes? if so where and if the water is coming out of the hinge hole does this indicated a door full of water up to this level?!!!:shock:
    Can anyone send me a pic of drian holes or advise on this matter.
    Just to be clear the previous owner had never used the car in the wet in 24 years apparently?
    Stuart
    Stuart
    This is a pic of my rear drain .mine has one in the middle and one at each end .the hinge is only about an inch from the bottom so i guess its possible that you've filled it to there:shock:.can you here it sloshing about?
    Good luck Steve
      Just check doors agian and there's water sloshing about in there:shock:I will have to make some holes then waxoyl the doors tomorrow.
      Thanks for your help stagdad much appreciated
      Another thinh I have notice is the seal between the glass and door top is shorter on the drivers door than the passenger door, should this seal be the same width as the glass or have 10mm each end clearance?:?
      Stuart
