Hi, I've noticed from some picture on the forum that maybe we are not allaware of the potential danger from the battery installation.
I hope this may be of use to some members.
The Postive terminal on the battery is very close to the mounting clamp bracket, which is earthed to the body - i.e. negative terminal of the battery (see below for danger).
It is very important than care is taken to ensure that the positive connection and cable are protected from the battery clamp bar. Fit the positive terminal clamp to ensure maximum clearance from the bar (horizontal)and fit and old piece of rubber hose around the cable where it passes over the bar.
Always disconnect the negative terminal first, when working with battery connections. If you undo the positive terminal first, there is a real danger of the spanner shorting between the pos terminal and the bodywork.
If this happens the spanner/cable/connector will weld to the bodywork/battery bracketand short circuit the battery- this is a fire/explosion danger.
A shorted battery will produce several hundred amps (600A), and thereby emmited several thousand watts of heat (5KW) and hydroden gas.
Hope this maybe of use.
Please correct any info given.
Mark.
Mark.
