VENT PIPES IN THE BOOT
    Just a question , why has the vent pipe from the filler got a filter in it as it goes to atmos?
    also on the top of the sender unit I have a pipe connection which has nothing connected to it, what connects to this as I am getting a right niff of petrol in the boot and in the car?
    cheers
    Tony
    Hi biglad ( is that a boast??) Dunno about the filter, but the extra pipe you have needs blanking off. I had the same problem, some people crimp the end, i used some sealant and a tyre valve cap!
      thanks Jason
        cheers
        Tony
        So it can vent to atmosphere, but sh1t, spiders etc can't travel the other way and contaminate the tank.....
        Russ
          so why hasn't the drain pipe that also runs to atmos got one?
            If it's the one I think you're referring to, 150835, it just drains water and spilt fuel from the atmosphere side of the filler cap - would be gilding the lily to put a filter on it...
              yes it is that one ,ok thanks for that.
              regards
              tony
                Tomy,
                I think the extra pipe which needs to beblanked off is to do with the US version where the breather and/or overflow from the carbs was connected back to the tank. Any fuel is then directed to the tank rather than dumping it on the floor as mine did whenone float failed to close the valve.
                Check the vent pipe is connected to the filler hose. Mine was loose and kept falling off so I put a jubilee clip on it.
                Phil
                  Thanks Phil, will have a look tonight
                  cheers
                  Tony
