Emission Test
    Emission Test
    Just had my 76 all original set up tested and apparently there are no issues as far as the garage are concerned. TDC 12degrees points at .38mm
    Just wondered what you all think and if there is anything that I should be adding to my list of jobs.
    squiggle 1.205
    CO 2.07
    CO2 10.1
    O2 5.0
    HC 155
    T 23
    Many thanks Mike
    All looks good to me
    Russ:dude:
      Good thats a relief. What is the first reading against a squiggle? Sorry to expose my ignorance. Mike
        Miles per gallon!
          Just over one I'm not doing too badly then. Anyone done an electric stag yet! Apart from Scalextric!
            The squiggle is the Lambda symbol - the Greek symbol for balance. It refers to the air/fuel ratio, and for our purposes is fairly irrelevant - it's for use with a closed loop fuelling system with a catalyst and would show a fault with an oxygen sensor in the downpipe.....
            2999 posts..........
              I guess that means you will not be posting for a while unless a great opportunity comes up soon to mark this next milestone......:P......what a dilemma as you can waste the next post replying to me:P:P:P:P:P
              Nigel
              Mk2 1976 Delft Blue with Beige Interior. TV8 and ZF 4 Speed
                Nigel
                Don't leave it too long Russ, or Russell might beat you to it!!!
                  Nigel
                  Stustag only needs another 402 and he will get there first
                    It seems that Russ is just too smart to be drawn in but he send me this pm
                    ......Aha!! Bet you thought you'd got me with that one
                    ....... so this pm could be considered post 2999 and a half....
                    Nigel
