GTX Magnatec
    GTX Magnatec
    Does anyone know if using Castrol GTX Magnatec 15/40W would be a problem in the Stag engine?
    I am asking as my oil needs changed and someone advised that only 20/50W should be used but I would have thought 15/40W would be better at the most crucial point when the engine is cold!
    Stuart
    Hi Stuart.
    Castrol Magnatec 15w/40 is fine for the stag engine as long as it is not a very worn engine as high oil consumption could result.Also if you have a recon engine you are best to run it in on 20w/50 before changing to 15w/40.I am currently using Castrol Edge 0w/30,but will be switching back to 15w/40 real soon as the gaskets seem to struggle to hold back the ultra thin oil
    Jon
      Thanks Jon I will go ahead and change the oil. The engine was fully rebuilt 7000 miles ago so is run in now!
      I've also bought a full oil leak kit so the new seals and gaskets should hold in my expensive new oil:shock:.
      Stuart
        Hi.
        If I were you I would stick with the recomended oil 20 / 50 for the engine, you could do more damage to the engine by changing.
        A friend of mine was told it would do no harm to his TR6 engine but he has just spent a fortune to totally rebuild it.
        I have just totally rebuilt my Stag engine, run it in for the first 100 miles on 20/50 drained it out, in went new 20/50 for 500 miles Changed oil and filter. I am now in Norway working and have driven a total of 2000 miles so far with not a spot of bother. I have only topped up with 1/2 litre of oil. The car is running sweet as a nut.
        1000 more miles to go then new oil and filter. I will be stickking to using Duckhams Classic 20/50.
        Paul.
        PS. Here is a pic of the car on the top of Hemsedal mountain at 1183 metres above sea level
          Stuart
          Conflicting views are of no use to you whatsoever so please seek more info on this
          subject for your peace of mind.
          Jon
            For a definitive answer on engine oils (and lifted from a previous thread) check here. If you've got a spare couple of hours.
