Triumph Technical Bulletin 73-C-1
    Hi found this:
    Vyback Rear Windows
    The Vyback rear window on convertible tops sometimes becomes badly creased due to incorrect stowage of the soft top assembly. We have found that these creases in most cases can be removed satisfactorily by simply filling a plastic bottle with hot water and rolling it across the creased area and at the same time supporting the opposite side of the window.
    Though it might be worth a try
    Mark.
    Sunshine works just as well, although a bottle of hot water is probably easier to come by at the moment!
    I also make a point of warming mine if at all possible before stowing the hood, either by leaving it in the sun for a few minutes or even using a hairdryer on a lowish setting - the window flexes better and is less likely to crease.
    Wendy
      Hair dryers will work but the hot water bottle trick is a safer bet.
        Wendy
        You have the advantage over us, Wendy. You probably have a hair dryer in that bottomless handbag you ladies carry
        Also, many of us don't needa hair dryer
          Yeah, it takes me ages to cultivate that "freshly dragged through a hedge backwards" look! And sadly the handbag is full of nappies for my two-year-old daughter these days. Still, at least she enjoys the Stag with the top down, it's not all bad, and then we both look a mess :?
