I can't say how frustrating a job re-assembling my rear brakes was today. No wonder most modern cars have discs all around.
Top pull off spring fitted to the hidden face of the shoes? Someones having a laugh! Self adjustment mechanism, especially designed on the same hidden face, so that when you connect the hand brake lever linkage and associated tension spring, and pop the toothed cam there's no way to reset it! I seem to recall in previous cars I've owned a hole in the back plate so a screw driver could access the purposely designed slot in the toothed pawl for said resetting adjustment. Ah, but that's just what Triumph thought we might expect. What about the circlip holding the brake cylinder to the back plate, lethal or what? I got it on eventually after chasing it around the garage a few times.And last but not leasedlets not forget those delightful little shoe hold down springs, collars and pins. O joy, with one hand compressing the spring with all my might, the other holding in the pin and keeping the shoe in place, my darling wife provided the third with a pair of long nose pliers to turn the pin thru 90. Easy! not after trying for a couple of hours to do it by my self.
The only thing that makes me feel better is knowing I'll pay anything to let a garage do it for me next time I need new brakes. Give me a cylinder head stuck on a block any day.
Anyone else have similar issues? Anyone else find it a doddle?
 how can that be done without stripping the shoes off? I think I might drill those missing holes.
