anti-vibration straps
    Anyone out there got thier carpets up? Do me a favour and measure the distance from the heal board out to the centre of the screw hole in therectangular backingplate, to which the anti-vibration strap fixings are secured from under the floor.
    If its as I suspect the plate should near enough nessel up to the heal board providing a restraint against turning when tightening from below.
    Hoping to drill the holes tommorow evening, so no rush .
    Hi John
    I haven't measured mine but you are right that they nestle up so that they don't turn
    Andrew
      Hi John
      One of my stags is on aspit right now and if you still need that measurement I can get it for you tonight.
      I never thought of those straps as "anti-vibration straps". Is that their real purpose.
      Dave L
        Thanks Dave, I'd appreciate the confirmation, But I'm just trying to figure out when tonight is in Canada? Isn't that tomorrow here?
        Thanks also to Andrew, sorry about the nestle spelling, I work for a competetor and we're not allowed to use the word, damn, I just did.
        Anyone else like to confirm the findings?
          When i had a bit of welding done on mine i had to redrill 1 hole, thesquare nut fitted tightly up against the heel board and inner sill onthe other side so i redrilled it match
          Stu
            Hi John
            have just measured up.
            If you have the bolt and the captive locking plate, then this runs up against the back and along the edge of the flat areaof the floor pan andlength ways it runs parallel to the sill.
            If not, thenthe centre of the bolt is 3/4 inch from the back and 1/2 inch from the side being measured from the start of the flat area of the floor pan.
            Hope this helps
            Andrew
              Thanks all, tomorrow night's job sorted.
              Andrew, thanks for the photo, I do have the locking plates so the hole position is now easy to locate.
              John.
                Its presently 16.30 hrs. I will send the info anyway
                Dave L
                  Sorry about the poor quality photo. Some one mentioned that the plate is captive but on both of mine the plate is loose and looks thicker than the one in the other photo
                  Dave L
                    Thanks Dave, the plate is 'loose' that is not attached to the floor, but is captive in so far that its prevented from turning due to its proximity to the heal board. The orientation of yours is 90 deg from Andrews, I think his is right, however lets put it to the populous to decide!
