Hello.
One of the jobs I will be doing this weekend ( apart from trying to find a knock from the front bottom of the suspension ) is to replace the Clutch Master Cylinder, Clutch Slave Cylinder and replace the hose with braded stainless. I admit I have not looked too closely but the new Clutch Master Cylinder mounting holes have a thread. A quick look at the one as fitted has bolts that go through the Master Cylinder mounts and into the bulkhead ( Into the pedal box ? ).
My question is when I fit the bolts to mount the Clutch Master Cylinder when I tighten the bolts when the bolts get to their end they may not be tight on where they go into as the bolts will be at the end of their travel and so the Clutch Master Cylinder will not be tight against the bulkhead. If the Clutch Master Cylinder had holes without threads the bolt would go through the hols in the Clutch Master Cylinder and into the bulkhead ( pedal box ) and allowing them to “push” the Clutch Master Cylinder tight against the bulkhead. Or are the nutsthat the bolts go into loose so allowing the Clutch Master Cylinder to be pulled tight onto the bulkhead ?.
I hope my explanation is clear. Am I missing something ( apart from brain cells ) or is it as easy as just removing the old one and fitting the new one. I know it is “fun” removing the clevis pin on the Clutch Pedal and also make sure that the bleed nipple on the Slave Cylinder is at the top.
Many thanks, Don Kennedy
