Exhaust / Gearbox clearance
    Hi Guy's
    Just go my MkII auto up on ramps, noticed the nearside exhaust is touching the gearbox casing, is this normal ?
    Err... No!
    Have you got the mounting bracket at the back of the gearbox?
    baz
      Yes Baz, mounting bracket is there, noticed though that one of the bolts is missing, and holes are not aligned, something's out of place I think's.
        Try again with the photo.....
          Definately think somethings out of place
            It look like previous owner has done a bit of a bodge on the joint between the two pipes, this may have something to do with the nearside pipe being too close in.
              Missing Bolt ?
                Looks like you'll have to undo all the rear clamps, re-align the pipes to the mounting then wriggle the the pipes into place, here's a pic of mine which will give you a rough guide of the clearance
                Baz
                  Err... I'm at it now:?, wrong pic, try this one
                    Thanks Baz,
                    willhave a gotomorrow after the saturday 'chores are done !
                    cheers
                      Er do you ever use your car !!!
                      I have never seen an underside in such amazing condition.
                      That is really impressive.
                      How do you keep it like that?
                      There is not even heat marks on the exhaust :shock:
                        This was posted earlier in the year about my refurb, done around 1000 miles in 4 months since, so i dont think it'll look like that anymore
                        Baz
