rev counter not working
    Hi All
    Looking for some advice on how the rev counter works,I've just had my gear box rebuilt after refitting we had trouble starting the car,ie:had no spark! after a lot of checking wiring connections we managed to get the car going,but now the rev counter is not working:X,does any of the connections on the coil have anything to do with the rev counter? I have the EJ Ward electronic ignition fitted,everything was working ok before the gearbox came out:?.any advice please. cheers Cliff.
    Cliff
    If you have a Mk2 and the revcounter is marked RVC on the face, then the white/slate wire on the negative (what would have been CB or connected to the original points) side of the coil has become disconnected or broken.
    If you have a RVI marked revcounter then the coil could be connected backwards......
    Russ:dude:
      Hi Cliff
      The rev counter is connected to the coil,i think it's the white/grey cable from neg side of the coil. Mk1 & Mk2 have different connections on the rev counters.
        kryten wrote:
        Cliff
        Russ:dude:
        Cheers Rus
        I'll have a look tommorow
          If you'd have posted this problem this morning I could have popped over, as I was just round the corner in Hampton sorting something for my father in law who lives there.....
            Well I've tried all the wires disconnected,reconnected, swap round,I cannot get the rev counter working very frustrating:Xshe starts and drives fine but no tacho!
            anyone got any ideas?
              RVI or RVC?
                Its a mk2 so I presume RVC also I have the EJ Ward electronic ignition fitted.
                  All fixed turned out be a broken wire just before the coil connection.
                    my rev counter is fluctuating and not giving a true reading of the engine revs - could it be a loost connection or maybe a faulty rev counter itself ???
                      RVI or RVC?
                        White/slate by any chance?
                          Hi Rus
                          Yes it was the white and grey wire,I had probaly pulled it off and on half a dozen times trying to find the problem so I was probaly making it worse:X.
                          So I'm all happy now and in love with my Stag again.Cheers Cliff.
                            Nice one Cliff
                            It's useful for others to know exactly what was wrong so if they have a similar thing in the future, they can do a forum search and find the answer....
                            Russ:dude:
                              Hi,
                              Did you find out why the rev counter was moving about? Mine does the same.
                              Matt.
