PAS Rack
    PAS Rack
    Hi All
    Is it really possible to recon my PAS rack at home or should I just stump up the £110 for a recon one?
    I think the rack went because I accidentally put Dextron 3 fluid in which I believe damaged the seals:X
    Reason I ask is because it is£17.50 for a seal kit but £110 for the rack and I am skint!:?
    Stuart
    stustag wrote:
    I am skint!:?
    Stuart
    You're a Stag owner - so what's new ? Martin.
      i would have thought Dexron would be ok for the power steering? - it is not like the gearboxthat has bands etc etc
        Stuart,
        I did mine recently from a kit, of course I won't know if I did a go job or not until I'm able to power the thing. It's assy, hopefully they were not affected by the Dextron fluid.
        Look at http://www.triumphstag.net/start/tec...g/steering.htm
          Hi John
          Thanks for this superb link.
          I am taking the car off the road to rebuild the steering rack,pump & column plus I will rebuild the diff with new bearings and CWP this autumn/winter.
          I will endeavour to take photo's of all this work for reference purposes for the forum
          Stuart
            Hi Stu
            Like you I have purchased the seal kit (from Paddocks) and simply need to build up the confidence to take the rack apart and have a go.
            Bruce
              stustag wrote:
              Hi John
              Stuart
              Hi Stuart,
              Did you get my PM? Might be an alternative to see you through until winter arrives.
                Hi Dave
                Sent you a PM in reply.
                Stuart
                  Stu i have a spare rack that i was given to me when i bought the stag.
                  I dont know if it is any good or not - but it might be good to have it to rebuild and leave your one on the car
                  PM if you are interested in it
                  thanks D
                    thanks D
                    Thanks mate for the offer but I will be rebuilding my current rack, I need to do some other jobs on the car so will take it off the road for a while
                    Stuart
                      john 4d wrote:
                      Stuart,
                      Hiya John, that's an amazing link, I've printed most of it off for future reference. Martin.
                        stustag wrote:
                        Hi All
                        Stuart
                        Stu, its not difficult as long as you think about what you're doing. The hardest bit isremoving the rod ends, I never found a way of simultaneously () undoing each end, also need large spanners. Internally be very carefull with the plastic seal spacers, they are not partof the kit and easy to break. I also leave the end cap loosish and tighten when on the mounting brackets. I could add more but easier by phone or message.
                        Have fun
                        Paul
