Help!
Ideas and suggestions please. A few months ago I posted that my oil pressure seemed to settle around 70-75psi hot. It was suggested that this was too high and either the pressure releif valve in the pump or a faulty oil pressure gauge was to blame or possibly it was fitted with a high pressure pump.
Well I stripped changed the gauge to a known good one from another car and it read pretty much the same. Next I stripped the pump and check the releif valve operation - all seemed OK. So I "invested" in a new pump
Fitted it and wow now I get 75psi at tick over and it increases linearly with engine rpm to over 100psi at 4000rpm:shock:. It still gets to 90 psi with a hot engine. I sent the pump back - its been checked by the manufacturer - no fault found - and a replacement pump supplied and fitted. Its exactly the same.
Three pumps, two gauges and all thats happened is the pressure is higher than ever. :XThere is good oil flow all around the engine right up to the topand no funny noises from the engine anywhere, (which says to me that something must be wrong
Any ideas whats wrong??
Thanks in advance
Thanks in advance
