water in the "V"
    water in the "V"
    Hi,
    Seem to have a pool of water in the V, car been stood about a week and pool under car as well - dried off water and tried to see where it was coming from - Front of engine but cannot see without removing airfilter and carbs etc.. - water will trickle out into the V if you squeeze the top radiator pipe - is it likely to be the the water pump? or is it the manifold ? or both without taking it to pieces any ideas -
    Seems like the winter time rebuild
    Doesn't take long to get filter and carbs off. Get a good idea of where it's coming from then. Found most of the water in mine was just a leaking hose.
      Top hose loose on thermostat housing?
        Top hose appears fine - no water leaks - as suggested will take filter and carbs off and see whats going on..
          Mine had a small leak in to the V when it was hot. This was one end of the "U" shaped hose under the carb on minewhich I hadn't changed sinceI bought it. Looked perfectly OK from the top and onlyfound it when I actually took the hose off.. :shock:
            Is that hose jewish?
              Hmnn hope you find it when you remove the air filter Steve butthats just howmine happened, couldnt see it even with the filter off but was told to expect 10 years from a water pump seal which is exactly how long mine lasted. Coolant appeared in the vee on mine as fast asI topped up the system so it was a serious leak but with the inlet manifold in place it was still difficult to see where it was coming from, small mirror on a stalk may be useful.
              Good luck
                Hi Steve
                It wont be the pump as it leaks when engine is normally running. It is going to be a hose or core plug. My betting it will be a loose jubilee clip.
                Good luck
                Andrew
                  Have to disagree Andrew, mine pi**ed out from the water pump seal when the engine wasent running, hope its not the pump though Steve.
                    Stagdad wrote:
                    [quote]Is that hose jewish?
                    cruelly cut by Rabbi Stanley.
                      Thanks all - especially the Jewish Hose - hope the Knife used on my Hose was a bit sharper for cleaner End !
                        Hey Steve any joy tracing the leak?
                        Youve got a new Stag appearing near you from this weekend, guy called Colin has just bought a white early J reg Mk1 from Cherrished Classics, heis a member of the SOC and lives at Laceby.
                        Looks a very nice car from the pictures, its got the American headrests fitted like yours but red leather.
                        Keep your eye out for him.
                          hi Dave
                          Thanks will have to look at water in V when off next week - New stag in area have u got contact details Laceby only up the road from me..
                            Hi Steve names ColinI livenear village. Contact me any time. Pick up car on saturday this week. Hope u sorted your leak and u hav fitted a new helmet! :P
                              Hi Colin (Rare1)
                              Welcome to the forum .You may be safer posting personal info like your address as a private message (PM) to one person especially as you will have a nice shinny stag parked there soon,You never know who is reading this.2 stags were stolen in Surrey recently.Just a thought ,Didn't want to worry you but thought it worth mentioning .You can edit out your address if you're worried now.
                              Enjoy your new toy Steve
