Next months article
    Next months article
    Mention “new world” and lots of people particularly those who enjoy a tipple, probably think of those rich and tasty wines from new vineyards around the world. If, like the 9,242 visitors the forum had last month (September), you had logged-in and had a look, you would have seen how an old club rule was applied to a new situation.
    Rule 17, the rule that caused a lot of emotion and discussion and like many of the other rules, probably needs a review as the nature and membership profile of the club evolves. If it were my choice, I wouldn’t bother with rules, but that is probably why it isn’t my choice!
    The BBC can replace Terry Wogan with Chris Evans, so radical change with a public institution is clearly possible and we watch with interest.
    Using the email stagforum@anvuk.com you can now ask the forum questions and David “Greenstag” has volunteered to help get the answers together and if we have any space in the magazine, hopefully publish as well. Obviously if you don’t send anything in, we cant respond, so over to you! In the unlikely event we cant sort it, Russ, King of the Green, Kryten and resident guru on all things triumph, will offer his wisdom with a personal response.
    Starting this month, we have Chris “V Mad” who has written up one of his projects when he helped a fellow member with a Weber Carb conversion. He has also written another one about his considerable experiences with Hoods and “Al-Stag” has written up the forums collective wisdom on the cooling system and modifications that can be used – both of these for later magazines.
    Thank you to these volunteers.
    Tonights posts include:
    • ebay Valuations
    • Oil pumps problems and where to source?
    • Water in the V
    • TR Clutch mod
    • Interior lighting problem
    • I thought modern cars didn’t rust…
    • Door switch / puddle light
    • Dash wood
    • PDWA Overhaul
    • Worried about your alloy wheels corroding?
    • Alphabet Soup.
    On that last post, it isn’t all technical stuff. Earlier this week it was reported that a large bomb was discovered attached to a can of Alphabet Soup. The bomb has been successfully defused. A police spokesman was quoted as saying, “ It could have spelled “DISASTER” if it had exploded!
    If you don’t already know how, you can access via the SOC web site at http://www.stag.org.uk/index.aspx or if you get stuck, email me at stagforum@anvuk.com and I will help you get on-line.
    We hope to see you on the on-line soon
    Graham
    I must have missed the ask the forum bit for the mag Graham - how's that going to work?
    Russ
      not entirely sure yet Russ... David Greenstag has volunteered to helpout - it could be posting and summarising responses or searching the forum for an answer. I havediscussed it with himbut he has asked me to write it down, so it probably isnt clear but lets see if anyone writes in before putting to much effort in!
        Graham,
        Nice one but you have repeated yourself when asking questions of the forum.
        Tim
          As per usual, a good article Graham. As per Tim's comments, remove the duplicated sentence.
          Bruce
            Thanks for spotting the duplication. I missed a bit-out and edited the post and what I sent to the editor with a please replace that paragraph with this paragraph. Editing posts on a mac looks completely different to a PC, and I usually make errors like this one....
