hi,
my stag has issues with the ignition coil breaking down when it's getting hot (eg after 40 miles.) it was normally boltedbetween the vee,in this position,and with a sharp throttle opening it loses the spark as the engine falters,this was proven with the aid of a inductive strobe light.with a steady thottle opening it's ok.the problem only occurs when the coil is hot.
so I temporarily repositioned the coil on the bulkhead and went for a drive andthere is a vast improvement.has any body else had this problem? I have bought 2 new coils with the same result.
I am using piranha electronic ignition what is the correct coil to use for this?
i have unipart plugs fitted,could this cause a problem?
shouldI bolt the coil to the bulkhead permanently?
any suggestions?
cheers
allan.
any suggestions?
cheers
allan.
