Head gaskets don't match on water jackets?!?!?!?
    Hi replacing my head gaskets again after last rebuild 800 miles ago, have heads off and im using the same gaskets as last time the thicker type from paddocks non payen type. Noticed that the gaskets have small holes rather than full sized water jackets im sure this is correct and to slow down flow or something. Are the payen gaskets different? If this is the norm then i will put it back together, couldn't find any other treads on this and can't remember what the original gaskets were like.
    Thanks in advance
    Paul
    Hi Paul
    As far as i can remember the original gaskets have a small hole over a large water gallery on certain cylinders and this was, as you say, to control the water flow around the head, as to it's merits i can't comment but from my limited knowledge of thermo dynamics coolant flow is managed by using a series of baffle holes that allow or restrict coolant flow retaining the optimum engine temperature - so in my opinion don't modify them and ensure they are as per original specification!
    But i am open to contradiction
    Quote from Rally Design
    And a note of caution! Enlarging gasket water-way holes will not improve cooling efficiency. The size, number and position of these holes has been finely calculated by the engine and gasket designers and any alteration may propagate localised overheating and premature engine failure.
    http://www.rallydesign.co.uk/cylinderhead.php
    Gary
      I can just imagine Triumph's designers poring over the fag packet now
        Hi Dave
        Smokey back room in some pub in Longbridge - same place they designed the "Easily removable Hard Top"
        Gary
          Hi Paul
          I replaced mine recently and I used Payen. They did have a few round holes where the holes in the block / head were oval, so your gaskets sound fine.
            Not much in Longbridge now it seems. I was in Birmingham last weekend and drove through Longbridge. Bl**dy great open space there now where the factories used to be.
            Several years ago I had to attend a course at a factory unit on what used to be the old MG Abingdon works , and last week I had to order some chemicals from a company that is on Herald Way, Coventry, part of the old Triumph factory site.
            Depressing isn't it?
              I think there is a Spitfire Close, Herald Ave, Dolomite Ave, and Vitesse something in Canley.
              ...........Andy
                ...........Andy
                Add to that Toledo Close, Renown Ave and Vanguard Ave
                  Andy Rundell wrote:
                  ...........Andy
                  MK 3 GT6 Crescent, Martin.
                    Is that a postcode?
                      Cheers guys just as I thought! Will put it all back together, just have to find out why they blew in the first place! oh the joys of stag ownership
                      Paul
                        Gentlemen,
                        There's a distinct danger of offending some of us true blue Coventrians here. Clearly the Stag was designed at Triumph's Engineering Centre at Canley, Coventry not at the Longbridge, Brummidgeham site belonging (at that time) to Rover Cars Ltd.
                        The Canley site does indeed have it's roads now named after Triumph models, including Herald Avenue but interestingly not a sign of a Stag. Herald Way is actually on the other side of Coventry (Binley) on another industrial estate built whilst the car was still in production (I think) on the site of what was a coal mine. There is a whole Stag Industrial Estate in yet another part of the city.
                        Adie
                        Non-historian, anally retentive, Triumph detail conscious...... Coventry born and proud of it!
                          I stand corrected, Adie. No offence intended.
                            adieturner wrote:
                            Gentlemen,
                            Adie
                            Hi Adie
                            Perhaps name a no through road after some stag waterways.
                            Mark
                              absolutely none taken Dave......I just thought you might want the accurate version:P
