Hi,
I've a noticable vibration between 38 - 44 and 65 onwards. Felt through the seat, not the steering wheel.Speed not revs related. I've done all the obvious, but am now out of ideas.
I've changed the tyres and wheels from Minatour to standard Stag wheels, vibration was worse ( heavier wheels in the equation?).
I've changed the propshaft to a brand new one. Slight improvement.
Changed the driveshafts to brand new. Slight improvement.
New outer subframe bushes (rubber). No difference.
New gearbox mounts (BW65). No difference.
New diff mount bushes, changed from poly to rubber. No difference.
Replaceddiff front nose, with good quill shaft & new bearing. No difference.
I changed the diff oil to 80W/140, hoping it would reduce the diff whine ( it did ), unfortunately it has made the vibration worse. No idea why.
New rear springs and rubber isolators.
Changed the rear drums for different drums, all it did was slightly extend the vibration to 44 - 46mph
Rear wheel bearings changed - no difference
Front wheel bearings and disks, calipers etc changed, no different.
Front strut bushes changed - no difference.
Gearbox was reconditioned 15K miles ago, I assume they replaced the necessary output bearings.
Diff was also reconditioned about 20K miles ago, before my ownership.
Am now out of ideas.....any suggestions?
 Martin.
 Martin.
