BW35 Auto Fluid leak
    Hi Folks.
    My BW35 box has ATF coming from many of the sump bolts even after the car has been standing for days. In desperation and to prevent the driveway and garage floor getting into a right mess, I have fabricated and fitted a drip-tray which hangs beneath the exhausts, until I can get the problem resolved.
    My questions are - (1) is the breather tube checkable with the box in-situ or does it have to come out to do this ? and (2) can anyone recommend an establishment in mid or south Scotland or in the north of England who could remove my box to fit new a new seal between the Torque Convertor and the box etc. which is where I am advised the problem may lie?
    MRO528L
    Hi Ian
    There are these people on the web but don't know if any good?
    http://www.tesl-phd.com/index.htm
    http://www.mackie-transmission.com/a...nsmissions.htm
    http://www.autotrans.co.uk/contact
    Stuart
      Thanks Stuart - Coincidentally I'm off to Glasgow in a few minutes to see an Upholsterer about re-trimming my '34 Jowett so I'll call on Mackie and discuss options with them. Thanks again.
      Cheers, Ian
        Hi Stuart - just back from Glasgow - saw Mackie's and they will do the job - remove the box and torque convertor, overhaul/recondition the TC (they say if seal gone the shaft neck will have picked up and need sorting), fit new seal and put back in car for £710 +VAT. I'm happy with that so will arrange to take the car up over the next couple of months since it gets laid-up over the winter.
        Thanks again. Cheers, Ian
          Hi Ian
          Glad I was of help and I hope they do a good job we can then add them to the list of forum recomended suppliers
          Stuart
            hi befor you spend all that money try a gearbox stop leak mine did the same thing as the oil seal goes hard this stuff softens it up worked on my car cost about £9 from halfords give it a try steve
              Worked for me as well
              http://stagownersclub.mywowbb.com/forum1/6278.html
              http://www.wynns.be/product.aspx?nav...64559&l=EN
              Mk 2 TV8 BW35 Pimento red 1975.
              AC Cobra AK427 5700cc 375hp 2011.
                Will do - going down to Carlisle tomorrow so will pop into halfords.
                Cheers, Ian
                  Cheers, Ian
                  Just wondering how you got on
                  Malcolm
                    Hi Malcolm. Didn't get as far as Halfords ! Will do as soon as I can although since car is not in use at this time (doesn't get used over the winter months) and covered up, I wouldn't be able to make use of it - presumably it needs activity in the gearbox for it to circulate and work ?. I am working 7 days a week at present restoring my '34 Jowett Tourer and anticipate this work continuing for a few more weeks. After that I will go back to the Stag and use it on any dry days we get!
                      I drove for only about 5 miles after putting the Wynn's additive in the gearbox,and the gear change improved a lot and its not dripped a drop of oil since.
                      Malcolm
                        Noted Malcolm. I have to go down to Carlisle tomorrow to drop off my Jowett running boards for sandblasting so I'll get the Wynns then and take the Stag for a spin on the next dry day. Will let you know the eventual outcome.
                          Hi Steve and Malcolm.
                          An update - FINALLY got a dry day on Tuesday and with my Jowett out of the way (at the paintshop) I have been able to address MRO's leak. Put the Wynns in and went for a run to Lockerbie and back (20 miles round trip).
                          LO AND BEHOLD the leak is GONE !
                          I have checked it each day since and NOTHING
                          I am staggered since I have never put much store in 'additives' of any sort.
                          However, it has saved me £750 at Mackie's so a BIG thanks for the suggestion
                          Cheers, Iandocument.write('[img]/images/emoticons/big_grin.gif[/img]');[img]images/emoticons/big_grin.gif[/img]document.write('[img]/images/emoticons/big_grin.gif[/img]');
                            Am very pleased that it worked for you, as well.I have recommend it to many people that they have all come back with good results.
                            Its a pity that Wynn's don't make a additive that would sort out my painful hip.
                            Malcolm
                              Snap - I have one too - the right side (or is that the offside ? !)
