Would be grateful for some Stag wisdom! After a trouble free thrash to Reading and back a couple of weeks ago I went to go out in the Stag and as soon as I started it up I could hear a loud knocking - similar to a bad big end knock but not quite as deep and solid. The oil pressure rapidly built up to 70psi and no difference.I popped the bonnet and determined it was coming from the front of the left hand head. I increased the revs and the noise increased with the revs though the volume and tone of it stayed the same. I decided to go for a quick drive to see if it changed as the engine warmed up - no difference!
Tonight I have removed the lefthand cam cover and checked all the valve clearances - they are all OK, the biggest being 20thou on one of the exhausts. I started it up, cold, with the cover off. The noise was very pronounced and definately not coming from the cam or any of the valves, but can be heard clearly coming from the depths of the timing cover. I removed the oil filler cap from the right hand head. The noise can be heard from there but not as loud as the left hand head side.
There is pleanty of oil flow to both cams, the cam buckets were still full of oil even though it had been sat for a week - so no issues there.
The speed of the knocking is in time with the cams - i.e about half engine speed. I have listened to the water pump and distributor. The distributor sounds sweet, the water pump also sounds oK but you can hear rhe knocking muffled in the background through a listening stick.
I suspect, but because I've never had it apart don't know, that it could be something to do with the jack shaft.
Any ideas/advice. Can the jackshaft be removed/checked without disturbing the heads/inlet manifold or do you have to remove the waterpump? Having replced the heads and seemingly got the cooling system sealed and sorted I am loath to disturb it!
Thanks in advance
Thanks in advance
