Hello,
After having removed the wheels when servicing the brakes, I put the wheels back on - only to find out that at a speed of about 70mph the front wheels start shaking.
When I took the wheels off again, I found that the holes in the rims were slightly too wide for the shafts of the nuts. So there was "play" and the wheels could not be centered properly, as they are not centered by a central hole in the rims.
Then I used a "trick": I fastened the wheels with conical nuts first hoping that those nuts would centre the rims. Then I replaced the nuts by the original ones - one by one. The result was better, but not really good.
I am already thinking of milling 60° conical recesses into the rim holes and have corresponding conical washers fabricated to solve the problem. I did this with the faked "Minilite" ("Minator") rims, which were sold to me by a German dealer. Unlike the proper KN Wheels (with conical recesses in the rim holes) the fakes have cylindrical holes. So I reworked the rims as described above and added conical washers - it helped.
Kind regards, Dieter.
