I'm feeling rather depressed!
Had my new toy for just under 1 week now and it's just overheated for the second time. The first time was on the day I got it - I was very nervous when driving it home when I discovered that the temperature gauge did not work. Needless to say it dumped all its coolant out by the side of the road. Luckily I'd broken down outside a pub and the landlady was very kind and gave me plenty of water to top up and I got home with no problems. The first thing I did was fix the temp gauge and been watching it like a hawk ever since. Today I noticed it start to climb above half way so stopped in a hurry, waited a while, then emptied 2 litres of water into the cooling system and proceeded back home with the gauge staying put on normal.
Car is a 1972 MK1 Triumph V8 manual. According to the service history the engine was rebuilt not so long ago and has only covered 50,000 miles in total.
I have several thoughts on what it could be:
1. The dreaded head gasket(s). On sunday I did a compression test and got the following results (8.5, 9.5, 8.25, 9.0, 9.0, 8.3, 8.75, 9.0). I'm no expert but I thought these seemed good - would these be more variable if the head gasket(s) have gone?
2. I have a MK1 radiator but it has a blanking cap and the MK2 expansion bottle. Both caps seem very old and tired. They may need replacing - should I use a 20psi cap on the expansion? I'm guessing right now its the 13psi from the radiator...
3. There is no bleed in the pipe to the top of the radiator (obviously Mk2 radiators had a brass filler cap but this does not). There will definitely be a large air lock here.
Obviously despite my suspicions I want to make very sure that I have eliminated all other possibilities before I look at taking the heads off. I think I'll start by fitting a header tank near the fuse box as per many folks's recommendations. Again, should I go for the 20psi or 13psi cap?
I should note that all hoses seem fairly recent, no visible leaks. I think coolant is being lost by being pushed out of the expansion bottle and I need to work out why.
Any comments ideas would be gratefully received!
