Why Are Easy Jobs Never Easy?
    Took the retaining bar off he battery to rub it down and repaint it. The rod that goes into the wing had been replaced with a length of threaded rod bent to form the hook at the bottom. It took me over an hour of bending my wrist the wrong way before it went back on:X.
    Took the car for a spin this morning the new coil has cured the cutting out I was getting. Haven't driven it with the soft top up for a while, seems more noisy than with the roof down.
    Phil
    Phil
    Why did you want to paint your battery?
    Bruce
      Phil
      Isn't that one of the joys of Stag ownership - continuous different challenges?:shock:
      As to the car being noisier with the hood up, I agree. I have been putting on new door seals and adjusting the hood and window frames to try and get it all a bit tighter and less draughty and hopefully quieter:?
      I have Steve (Stagdad) riding with me on the London Run, so didn't want him going home with a crick in his neck:shock::shock:
      Rgds....Al.
        Rubce wrote:
        Phil
        Bruce
        Doh. Message to self check read and re read before clicking post
        I painted the retaining bar. I wasn't aware Batteries were male either:P
        Phil
          Hi Phil, next time, remove the offside outer headlight and bowl, 5 minutes, then you can easily get to the bottom of that clamp - s easees. Martin.
            I had that problem twice on Saturday!:X
            If you don't mind a hijack - I am interested to see if your problem was similar to mine.
            It runs great for 3-4 miles then starts to feel a bit lumpy. come to a stop and the engine dies and will not restart. Wait 5 mins and it starts. and no the bottom of the coil is NOT resting on the engine block.
            I serviced it recently and installed a new Lucarse cap and distributor. I am thinking that the old coil would look better in the engine bay :?
              Yes that sounds exactly the same.
              The motorway is about a mile from me and just as I pulled out to overtake the string of lorries the engine just died. Scary for a while trying to get back to the hard shoulder.
              I had been having the carbs flooding so had assumed this was the problem but after stripping and balencing the carbs the car still stopped.
              Since fitting the new coil its been fine so far
              Phil
                is your coil ar the rear end of the car
                  No but it will be in the rear end of my local - soon to bequite unfriendly -parts supplier. :dude:
                  Now where did I leave my box of latex gloves :P
                    lol
                    try pertronix flame thrower coils ,mine been on four years .not a moments trouble
                    i do not run a 6 volt coil though,nor have a ballist resistor or wire
                    alan
                      This is the Forum at its worst.:shock:Why didn't you intuitively know that I was going to do this and warn me before I started
                      Thank you anyway
                      Phil
                        Thank you anyway
                        Phil
                        sorry !
                            Thank you anyway
                            Phil
                            sorry !
                            Martinlives further away from you thanI do Phil, the power of the Topaz won't reach that far north
                              But there are a few on the way to relay it
                              Phil
