Fuel Pumps
    Fuel Pumps
    Hi Guys Anybody fitted Facet pump ,seems a lot cheaper than S.U one at under £40Thanks Regards Doug
    Hi Doug,
    No personal experience but apparently thay are noisy, and run all the time as apposed to the SU pumps that are quieter and only run when required.
      StagnJag wrote:
      Hi Doug,
      I prefer the ones that switch off when the car is not in use
      Hows that motor then Dave - all running ok?
        I have used facet pumps on several vehicles, they must be mounted on rubber bobbins or they rattle annoyingly. Seem to last about 20,000 miles then gradually hammer their rubber non return valves to pieces which end up in the carb needle valves if you forget to fit a filter before the carb. Eventually they just rattle and don't pump. I have also used a facet interuptor pump on a high powered RoverV8 and after a few years I had to tap it to get it to start just like an SU pump:X
          grahamb wrote:
          StagnJag wrote:
          Hi Doug,
          Apparrently finished. I am set up to pick it up on Wednesday afternoon
          YIPPEE
            Glad its all done. Were you brave enough to ask what the damage is?
              I did, he hadn't worked it out when I spoke to him!
                Don't forget they don't take plastic - only cheques or cash.
                Mind you they did give me an invoice and let me do a bank transfer.
                  thanks Al, although Trevor mentioned that. I have dusted off the cheque book!
                    I phoned them today about my clutch. They said that they couldnt talk as they were in the middle of working out something massive....:shock::shock:
                      oh!
                        Fit a Carter pump; it fits the Stag mounting points and works in a similar manner to the Stag unit.
                        Nice solid metal body and unions and pumps sufficient fuel for most uses.
                        Available from Real Steel for around £50.
                          Got a problem with my pump/carbs (su type) plenty of fuel in tank,turn on ignition ,pump ticks continually,fuel filter in engine bay looks full so where is the fuel going.I think i have seen a similar topic on the forum recently but cant find it now.Can anyone help.
                            Do you mean if you disconnect the fuel pipe from the carbs the fuel is spurting out from the fuel pipe in tune with the pump ?. If so, then not pump/fuel related. More ignition/firing problems it seems.
                              Hi Guys
                              Anyone wanting to keep their SU can convert it to electronic by getting a kit
                              http://www.sucarb.co.uk/ProductDetail.aspx?Id=33152
                              Good value to currently
                              Gary
